Piston to cylinder clearance
Postby Pat the Jawa » Tue Aug 09, 2016 3:26 pm
Does anyone know the correct piston to cylinder clearance for the TS250/1? I'm considering getting a rebore and need to be able to tell the technician how much clearance to leave.
Pat the Jawa
Re: Piston to cylinder clearance
Postby Guesi » Wed Aug 10, 2016 5:19 am
With original pistons 0,04 mm.
With Almot pistons you need more, some take 0,05 mm or more. The more you take, the louder the engine will be when cold...
Guesi Motorradteile
MZ spare parts
Postby Pat the Jawa » Fri Aug 12, 2016 1:48 pm
Thanks for the advice - much appreciated! Just checked the 0.06mm converted to thou and it comes out at 0.0015" which seems a tad small to me? I do remember from past experience that MZ pistons have a pretty tight fit in the cylinder but is it really that tight? Cheers, Pat
Pat the Jawa
Postby Guesi » Fri Aug 12, 2016 3:15 pm
According to the MZ literature it is 0,04 mm on TS and 0,05 mm on ETZ 250 engines.
Guesi Motorradteile
MZ spare parts
Users browsing this forum: Bing [Bot] and 15 guests
