help i have problems
Postby pknutts » Fri Aug 05, 2016 11:27 am
i have an electical problem on my etz 250
the engine running off the battery draining it if i use lights the go dimer when engine is running
i have had a repalcemnt alternator a new reulator/recterfier also new elcttronic ingntion
pknutts
Re: help i have problems
Postby AlanJ » Sat Aug 06, 2016 3:56 am
Hi, You do not mention the battery and it makes me wonder if that could be the problem and your electronics are trying to cope with an ailing battery. Just a thought. wish you well Take care Alan.
AlanJ
Postby pknutts » Sat Aug 06, 2016 4:17 am
could be the battery i was told by the guy i got the bike off he put a new battery on just before i had it :smt006
pknutts
Postby pknutts » Sat Aug 06, 2016 5:18 am
ive put a muilti meter on battery when bike is running its reads 11.79ish so its not chargeing so i can rule out battery
pknutts
Postby keleto » Sat Aug 06, 2016 7:39 am
Could be a lot of things. Bad carbon brushes on the alternator. Incorrect wiring or bad connection anywhere. Bad rotor, stator, rectifier or regulator. If you are handy with a multimeter it shouldn't be a huge job to get to the bottom of it.
keleto
Postby pknutts » Sat Aug 06, 2016 9:53 am
all sorted now just a bad conection at the fuse
thank you alan for your comments
pknutts
Postby keleto » Sat Aug 06, 2016 12:02 pm
Check the simple stuff first, yeah :-)
keleto
