cutting out
cutting out
Postby rcbikeracer » Wed Jul 13, 2016 4:54 am
Hi folks, I have a 96 Skorpion which cuts out once nearly every ride out. It does this at a random moment in the middle of a 40 to 50 mile trip over various roads. It will cut out when slowing for a junction or roundabout. But it only happens the once, sometimes it doesn't cut out. It will restart straight away on the button. So I have my duct tape, WD40 and a hammer, where should I be looking. :roll:
rcbikeracer
Re: cutting out
Postby droy » Wed Jul 13, 2016 5:18 am
Sidestand switch - see some recent posts in the 660 section.
Is it at a specific RPM?
[b]Gang of Four
1997 Replica
1996 Tour (Track Day Project)
Montclair, NJ USA
droy
Re: cutting out
Postby rcbikeracer » Wed Jul 13, 2016 5:46 am
Cheers I will check the side stand switch. It cuts out at lower revs typically going from 3rd to 2nd or 2nd to 1st, At all other times it has a good strong tickover and runs well :?
rcbikeracer
Re: cutting out
Postby DAVID THOMPSON » Wed Jul 13, 2016 4:48 pm
Check spade lugs on coil
And try a testride with a bungy cord on the side stand its switch may need adjusted
And bumping the kill switch can cause glitches
Some of the bikes need some tlc there allmost as old as the riders
Dave
Loose wires and spades do not like sharp bumps
Re: cutting out
Postby MZCountryRider » Thu Jul 14, 2016 8:34 am
My brother's Aprilia Pegaso 650 Cube did that when temps were below 60F. Once I made the idle mixture slightly richer, it stopped doing it. Went from 2.5 turns out on the mixture screws to 4 turns out.
Charlie
'69 Guzzi Ambassador
'71 Guzzi Ambassador
'72 Benelli 175 Enduro
'73 Guzzi Eldorado
'76 Guzzi I-Convert
'77 Morini 3 1/2 Strada
'81 Ducati 500SL Pantah
'82 Moto Guzzi V50 III
'97 MuZ Skorpion Tour
MZCountryRider
Re: cutting out
Postby rcbikeracer » Thu Jul 14, 2016 10:38 am
Hi folks, Checked the side stand switch, It does not do anything, thinking It may have been bypassed somewhere in the wiring loom. Weather permitting the tank will be off tomorrow and wiring connections will be prodded and poked and checked with my trusty old meter.
Today warm and sunny did 54 miles to the seaside, after 20 miles it died changing from 2nd to 3rd, then 5 miles later died going from 3rd to 2nd. Both times started straight away on the button. All other electricky things, lights, indicators working as normal.
I shall post my findings, if indeed findings are found
rcbikeracer
Re: cutting out
Postby DAVID THOMPSON » Thu Jul 14, 2016 3:01 pm
defective neutral light switch making false signals when shifting or a bad diode ????
all those diodes make it all work
but i call them A BAD, GOOD IDEA because there so hard to trouble shoot a problem
if one is going bad
inspect the wire from the neutral switch for proper hook up and intermittent shorting
Re: cutting out
Postby rcbikeracer » Thu Jul 21, 2016 8:18 am
So this week, tank off, checked every spade and connector I could see, a little minor corrosion, zapped them with a little WD40. I am just back from a 25 mile run and it seems fine. Fingers crossed as I'm doing the Helmsley TT next week. So thanks for the ideas and suggestion.
rcbikeracer
