Removing the clutch cover on my MZ ETZ 250/1 1986
Postby Rocky8 » Thu Jan 21, 2016 3:12 pm
Hello list members.
This is my first post to the group and really need your help. I have been trying to remove the cover of the clutch and kickstart on my MZ ETZ 250/1 engine which I received without the kickstart on it.
I noticed that the kickstart shaft is not at its correct position (rotation place) and the spring has moved from its stop position in the cover. There is a binding on both the kickstart side and the clutch side and I have been watching all videos of the removal on a newer model with the oil pump in the cover, and all fastener are off. I am doing exactly the same as on the video, but have been using a soft mallet to try to loosen something, and am about to damage the cover if I do any more. There seems to be something loose and binding under the cover but I can not figure it out what it could be.
Can anyone here help before I start using the saw?
Johann G.
Iceland.
MZ ETZ 250/1 1986.
Rocky8
Re: Removing the clutch cover on my MZ ETZ 250/1 1986
Postby Rocky8 » Fri Jan 22, 2016 5:05 pm
Just wanted to inform you that we managed to remove the cover with a lot of chisel work and banging. The bearing on the clutch was binding, and the spring on the kickstart shaft broken and was interfering with the gear drive.
Johann
Rocky8
Postby therealche » Fri Jan 22, 2016 6:37 pm
Glad you sorted it without our help! Strangely enough I have just been reading a post ( on a FB forum) from someone who want's to take his MZ to Iceland later this year
therealche
