Mastiff brake bleeding
Postby Mimmi123 » Thu Dec 31, 2015 9:20 am
Hi everybody!
I am new member and I have a Mastiff with brake problems. I took the bike apart to give it an overhaul.
I had to replace the front master brake cylinder because it was leaking like a sieve.
I used an old, but working, Yamaha YZF 125 master cylinder I had in a box of left overs.
Oddly enough, I can´t seem to be able to bleed the front caliper, no matter how I go about it.
I have had it off the bike, but not taken it apart.
The same problem with the rear brake. Can´t bleed it. I have tried the normal way as well as using vacuum to suck the fluid through the bleeding screw.
Nothing happens.
I need all the knowledge of this forum.
Mimmi123
Re: Mastiff brake bleeding
Postby DAVID THOMPSON » Thu Dec 31, 2015 9:25 pm
some have had a problem with the piston in the master cylinder not returning to its proper
resting point so the hole does not open to allow new fluid into the mastercylinder
if the piston does not return to a proper resting place no new fluid can get from the storage tank
and into the system
this can happen on both the front and rear from a poorly adjusted break lever not allowing a full piston return
when working on my rotax powered saxon tour i had to push fluid up from the brake to the top
the air just refused to flow out of the system in the down direction
also plastic speedo faces and windshelds HATE BRAKE FLUID paint does also
