Uprated starter clutch available from Grahams
Postby crocodilemick » Thu Jul 30, 2015 5:56 am
Hey guys, thought I'd let you know - just been speaking with Ian at Grahams, MZ have sourced improved internals for the starter clutch and have started shipping (via Grahams), they're a bit more expensive (£130 ish instead of £115). But if they don't break, then it'll be worth it.
crocodilemick
Re: Uprated starter clutch available from Grahams
Postby DAVID THOMPSON » Thu Jul 30, 2015 7:55 am
this has been a problem from the beginning
if you find a 125 that has been setting for a long time ..do not start it with the electric starter
new fresh gas in the carb and new oil and filter then bump start it down a hill
let the sprag clutch get oiled up by running it for a long ride
as they dry out over time
and use an oil rated for wet clutches
Users browsing this forum: Bing [Bot] and 3 guests
