A sad tale and request for help please - Skorpion
Postby Manx Skorpy » Sun Nov 09, 2014 2:42 pm
Hi Folks
I'm from the Isle of Man (yay!) and my best mate had a Skorpion, yellow with fairing, is that a Sport? - I say had, as he was unfortunately killed in a freak low speed accident last TT week on another bike. I think he had posted on here occasionally. :( RIP, Gaz.
The Skorpy has been left to a friend in England and I have been keeping it going for my pal's widow until it can be taken across. It has always fired up no problem until....the last time, when nothing at all happened on pressing the starter button. Everything else works, battery is charged, but there is one odd thing, the high beam comes on if you pull the clutch in and press the starter button. Any ideas where to start? The solenoid isn't clicking in, nothing at all happens.
I'm quite savvy with bike mechanics but on Hondas and old Beemers....this MuZ/Yam thing is all new to me.
Cheers
Neil
Manx Skorpy
Re: A sad tale and request for help please - Skorpion
Postby Nobog » Sun Nov 09, 2014 2:59 pm
Check the ground from the battery to the frame.
Jim
Nobog
Postby Manx Skorpy » Sun Nov 09, 2014 3:29 pm
Nothing so easy - tried that thanks!
Thanks for posting.
N
Manx Skorpy
Postby DAVID THOMPSON » Sun Nov 09, 2014 6:36 pm
read about the relay 19 problem its also labeled 30 on some drawings maybe 21 on some
it controls electric to the whole bike and with some diodes the sidestand switch and neutral lamp
as a safety switch
on the one your working on there may be a switch on the clutch lever if it was raced
it will be wired so bike can be cranked if clutch is pulled in
the clutch sw is not on any mz i have but may be on some models
also check the big relay under the seat for the stater its coil may have gone bad
the relay 19 is about 1 inch by1 inch by 3/4 inch
can be replaced by a relay from halfords that has 5 lugs a double pole single throw
Halfords HEF557 Relay 12V 30A 5 PIN
Postby Manx Skorpy » Tue Nov 11, 2014 4:41 pm
Hi David, some useful tips there, I will have a check through that relay. The bike hasn't been raced, it's a standard road bike bar the loudest pipe I have ever heard - no MOT's here! No Halfords either for that matter, but I should be able to source a relay from the interweb.
Cheers
Neil
PS - It definitely has a switch on the clutch lever.
Manx Skorpy
Postby DAVID THOMPSON » Tue Nov 11, 2014 6:05 pm
this helps for a quick re start if your stalled in traffic
no hunting for neutral so the button works
i do not think my traveller has it but to lazy to crawl off to the shop to look tonight
my git up and go seems to fall on its ares earlier in the day than it used too
Postby Manx Skorpy » Fri Dec 05, 2014 4:01 pm
Agreed - get up and go went when I turned 50!
Could anyone guide me to this relay please? Is it under the tank?
ta
Neil
Manx Skorpy
Postby Old Dog » Sat Dec 06, 2014 4:17 am
You have tried the kill switch on the right handlebar and the sidestand switch on the sidestand?
It is under the seat - runs to the battery
All the best
Old Dog
Old Dog
Postby Manx Skorpy » Thu Feb 05, 2015 9:29 am
Turns out the issue is a short in the l/h switch gear - it is a bit slack on the bar and had twisted when turning the cho0ke on. Pushing it back has stopped the headlight coming on when pulling the clutch, and it now fires up! Horrayy! Gary's widow was pleased, he left the bike to a pal in England and he'll be coming to ride it TT week.
Manx Skorpy
Postby Manx Skorpy » Thu Feb 05, 2015 9:31 am
Old Dog wrote:You have tried the kill switch on the right handlebar and the sidestand switch on the sidestand?
Oh yeah, tried those first! :-D
Bloody thing is soooo loud, it really has a bark.
Manx Skorpy
