Autolube to PreMix
Autolube to PreMix
Postby paulatradese-6 » Fri Aug 22, 2014 3:33 pm
Sorry if this has come up before, but I have an ETZ 250 that I have been running fine on premix, for years. I just left the oil pump in-situ and blanked the external crankase oil ways off with metal putty.
The question is that I have since heard that it is better to take the oil pump off. Now I want to convert a 251 engine to pre-mix but don't know wether I should remove the pump or not.
paulatradese-6
Re: Autolube to PreMix
Postby den » Sat Aug 23, 2014 6:54 am
why not leave the pump in place , re-route the output tube and make you own scottoiler automatic chain oiler for free,,get where im going here,, :idea:
den
Postby paulatradese-6 » Sat Aug 23, 2014 10:09 am
den, I like your thinking
paulatradese-6
Postby therealche » Sat Aug 23, 2014 6:53 pm
But with the wonderful MZ enclosed chain system the slight leak from the neutral switch is enough to keep the chain lubricated Take the pump out, sell it, spend the money on beer. It's the MZ way
therealche
Postby Linegeist » Sun Aug 24, 2014 7:54 am
therealche wrote:But with the wonderful MZ enclosed chain system the slight leak from the neutral switch is enough to keep the chain lubricated Take the pump out, sell it, spend the money on beer. It's the MZ way
This man is truly a genuis!!! :mrgreen: :smt023
Linegeist
Postby paulatradese-6 » Fri Sep 05, 2014 3:01 pm
den wrote:why not leave the pump in place , re-route the output tube and make you own scottoiler automatic chain oiler for free,,get where im going here,, :idea:
Have carried out this mod. Fed tube to the top of the chain gaiter, and threaded it underneath where it meets the engine cover. Lubes chain fine. Premix also fine.
paulatradese-6
Postby DAVID THOMPSON » Fri Sep 05, 2014 4:47 pm
take the rubber covers off at winter service and clean up the mess...
it can be a fire hazard if a bearing or the brake gets toooo hot
and it also drips on the pavement when parked at the girl friends house ...
this lets her husband know you stopped by :smt006 without permission ...
D
Postby Blurredman » Thu Jan 22, 2015 1:21 pm
I left mine in place, but after letting oil get through the system, I then looped the pipe back around from the output back into the input. It now pumps oil eternally and doesn't size for being dry, if ever I want to put it on.
