Head Gasket
Head Gasket
Postby suzukix7 » Tue Jul 08, 2014 1:19 pm
Hi guys,
Does a 1979 TS 150 require a head gasket?
Many thanks
Dave :?:
suzukix7
Re: Head Gasket
Postby Agronski » Tue Jul 08, 2014 2:18 pm
Nope, no head gasket.
...but if you think the head is leaking, you can always smooth the mating surface down a bit with some grinding paste or 800-1600 grit sandpaper on a bit of perfectly smooth glass. Plenty of hints about good grinding technique online.
Also, make sure the head bolts are torqued to the right spec - M10 nuts, so about 10Nm (9ft-lb). Be sure to tighten them in a diagonal pattern to avoid distorting the head.
___
Agronski
Re: Head Gasket
Postby suzukix7 » Thu Jul 10, 2014 11:12 am
Many thanks Buddy :D
Dave
suzukix7
