what lube ?
what lube ?
Postby MichaelTorre » Fri May 09, 2014 1:13 pm
We have enclosed chains on our bikes.
What do I lube the chain with to ensure a long life ?
I don't see how grease will work after it gets flung to the corners
of the covers.......and gear lube will make a runny mess.
M
MichaelTorre
Re: what lube ?
Postby vicar » Fri May 09, 2014 3:08 pm
Paint a thin coating of gear oil on the chain, it works just fine.Gear oil is sticky and the long chain hydrocarbons have extra strong bonds at a molecular level that helps it to stay on the chain and not fling off. ( Ho Ho what about that for true bullshite)
Yes if you drench the chain with it it will run off and make a mess the secret is the thin coat.
vicar
Re: what lube ?
Postby MichaelTorre » Fri May 09, 2014 11:58 pm
Some how, I am under the impression
that I have to have enough lube in that cavity,
that it's circulating keeping the chain "damp" with lube.
M-
MichaelTorre
Re: what lube ?
Postby DAVID THOMPSON » Sat May 10, 2014 6:38 am
huge amounts of grease on it NO
do take the cover off and lube once in a while
its a great idea except on a lot of bikes the thing never gets serviced till it fails
and the chain proper adjusted so it does not ware the rubber covers
Re: what lube ?
Postby MichaelTorre » Sat May 10, 2014 4:21 pm
Seems then I am over thinking it.
I am a bit of a fuss budjet, so the fastidious adjustments are no big effort.
I can use standard chain lube and keep it well maintained.
M-
MichaelTorre
Re: what lube ?
Postby DAVID THOMPSON » Sat May 10, 2014 4:53 pm
the big deal is proper adjusted chain
so it does not ruin the rubbers
extra grease helps
but its also a fire hazzard
