headlight assembly
headlight assembly
Postby kiwien » Sat Apr 19, 2014 6:15 am
Hello i am a proud new owner of a mz ts 150
Im having problems about getting the chrom ring on to the headlight, When i try to assemble it, it will always be sitting Kinda crooked, sov that one side will fit perfectly and the other side will be sitting about 2 cm. Longer out than supposed to, how do i get this right?
Thanks in advance :-)
TS 150
kiwien
Re: headlight assembly
Postby DAVID THOMPSON » Sat Apr 19, 2014 6:30 am
the shell is not round ...you just have to play and fiddle with it some times there a real pain
the one on my 1953 bmw is a beast to get refitted
past owners wrecked it toooo many times
Postby kiwien » Sat Apr 19, 2014 8:00 am
DAVID THOMPSON wrote:the shell is not round ...you just have to play and fiddle with it some times there a real pain
Okay i will try to fit it, thanks for the fast answer :-D
TS 150
kiwien
Postby arry_b » Sat Apr 19, 2014 12:12 pm
Have you ever seen the chrome ring fitted to the headlight bowl? Or did it come dissembled? It could be the wrong ring, it should be perfectly circular - perhaps someone's distorted the headlight bowl.
They clip in top first, then the attachment at the bottom pulls together with the 6mm screw which is at the very bottom of the light unit. 2cm is a LONG way off being correct. Got any pictures?
arry_b
Postby Guesi » Sat Apr 19, 2014 1:05 pm
MZ had 2 different chrome rings.
One for the TS models, one for the ETZ models. they are slightly differnt in diameter.
Maybe you have the wrong one.
Guesi Motorradteile
MZ spare parts
Postby kiwien » Sat Apr 19, 2014 5:59 pm
arry_b wrote:Have you ever seen the chrome ring fitted to the headlight bowl? Or did it come dissembled? It could be the wrong ring, it should be perfectly circular - perhaps someone's distorted the headlight bowl.
It did fit once, before i took it of to polish it and redo the wirering, i dont have any picture right now, but i will put some up tomorrow :)
TS 150
kiwien
Postby kiwien » Sat Apr 19, 2014 6:00 pm
Guesi wrote:MZ had 2 different chrome rings.
i would guess its the right one, since it did fit when i first got the bike :)
TS 150
kiwien
