Seized Engine.
Seized Engine.
Postby kevmead » Thu Feb 13, 2014 6:10 am
Hi all,
After a bit of advice, i have recently been given a 96 plate etz 251 off a friend in bits. The engine has seized from being stood in the garden for a few years and i was after the best advice to try and un-seize the engine without a lot of expense. I have had tried tapping the piston with a bit of wood after filling it with oil but no luck. Any help would be appreciated as i am not that clever with engines to be honest.
Many thanks,
Kev :D
kevmead
Re: Seized Engine.
Postby DAVID THOMPSON » Thu Feb 13, 2014 11:53 am
a long soak with liquid wrench and if it does not move then
its a lot of work with a Dremel Tool
when using the wood block remember that both the piston and rings may be stuck
and a piston that has been beat on with a wood block and hammer will damage the ring groves
if it took a lot of pounding
a new piston and rings need to be on the shopping list
at rebuild
Re: Seized Engine.
Postby MZCountryRider » Thu Feb 13, 2014 1:20 pm
Try filling the cylinder with a 50/50 mix of acetone and atf (automatic transmission fluid). Let it soak for a week or more and see if that helps to break it loose.
Charlie
'69 Guzzi Ambassador
'71 Guzzi Ambassador
'72 Benelli 175 Enduro
'73 Guzzi Eldorado
'76 Guzzi I-Convert
'77 Morini 3 1/2 Strada
'81 Ducati 500SL Pantah
'82 Moto Guzzi V50 III
'97 MuZ Skorpion Tour
MZCountryRider
Re: Seized Engine.
Postby therealche » Thu Feb 13, 2014 5:35 pm
Two to try
1) Diesel . Just keep filling it up with diesel for a week,Give it a healthy tap... then repeat. Worked for me on a couple of well seized engines
2) Heat around 100ml of oil to smoking heat, then pour into the combustion chamber. Seems counter intuitive but I knew someone that swore by it. Something to do with thermal shock. Mind you if you have soaked in something inflammable before I would stand well back!
therealche
Re: Seized Engine.
Postby Lone-Wolf » Thu Feb 13, 2014 7:02 pm
Wotcha.
The ETZ I recently bought had seized due to standing. A mixture of diesel and penetrating oil down the plug hole, then heat the barrel with either a blowlamp or a hot air paint stripping gun. When the barrel is smoking nicely, put the bike on the centre stand, engage top gear and give the back wheel a good turning. This freed up the engine of the bike I'm using now . . . . .hasn't done it any harm ( yet ).
Lone-Wolf
Re: Seized Engine.
Postby DAVID THOMPSON » Fri Feb 14, 2014 10:35 am
when one sticks on me i like to take it apart and clean it up inside
an old BMW /2 is bad about dampness behind the valve seats in the humid wx we have here
and needs to have the spark plug removed and warm it up for a few hours or even a few days
so when it starts it does not pop the seats out .....from the steam pressure
seen this happen several times here in the valley
Re: Seized Engine.
Postby kevmead » Sun Feb 16, 2014 2:00 pm
Hi all, just want to say a big thankyou foar all your advice. After soaking engine with PlusGas for 24 hrs , a bit of WD40 , bit of force with mallet and wood i have finally managed to unlock the engine. :D
kevmead
Re: Seized Engine.
Postby DAVID THOMPSON » Sun Feb 16, 2014 5:58 pm
do take it apart for a good look
make sure you did not break a ring or mess up the piston
Re: Seized Engine.
Postby vicar » Sun Feb 16, 2014 6:10 pm
Pleased you got it free,
if you are ever out on the road and get a seizure put the bike in gear and push it backwards. Its worked for me in the past when the piston was seized and I could stand on the kick start to no effect and I am a fat bloke ........
vicar
Users browsing this forum: No registered users and 39 guests
