Winter Storage
Winter Storage
Postby den » Sat Nov 30, 2013 6:44 am
As the subject suggests im looking for advice hints and tips on winter storage,I never ride in the cold wet winter months its too dangerous and the salt on the roads ruins the bike,,I have a dedicated outside garage for the bike and some bike covers,i have the bike jacked up off the ground with a home made hydraulic lift and a battery optimiser to keep the battery alive,,(keeps the gps tracker alive too)
I found when i did the gear change mod last year ther was a little rust on the clutch push rod,,condensation from starting over the winter and then cooling,,should i still start or seal the engine breather?? or not bother running the engine at all,,
Your comments please,
den
Re: Winter Storage
Postby den » Wed Dec 04, 2013 12:31 pm
what mmmmm,,this topic not exciting enough or just all replies would be just common scense.
oh well,,
:smt006
den
Re: Winter Storage
Postby Srinath » Wed Dec 04, 2013 12:58 pm
Well the whole enchilada is - change oil and filter or if oil isn't too old, take a long ride..
Then Drain tank, drain carbs, put battery on charger ...
Cool.
Srinath.
Srinath
Re: Winter Storage
Postby mdouglas71 » Wed Dec 04, 2013 1:23 pm
You don't need to seal anything. Just change the oil and filter a little bit later. Keep the battery on a trickle charger, otherwise if you're storing it for 2-4 months. Honestly, you can just go start it up once a month and that'll be sufficient in keeping the oil cycled.
mdouglas71
Re: Winter Storage
Postby den » Thu Dec 05, 2013 4:19 am
cheers for that , i think i may just bring the bike in the living room and decorate it for christmas and use it as a tv stand for the new year ,Its a work of art anyways,, may just put it on the wall
den
Re: Winter Storage
Postby therealche » Thu Dec 05, 2013 5:26 am
den wrote:cheers for that , i think i may just bring the bike in the living room and decorate it for christmas and use it as a tv stand for the new year ,Its a work of art anyways,, may just put it on the wall
Now you are thinking like a true MZer!
therealche
