SLOW RIM LEAK
SLOW RIM LEAK
Postby AIRMANBEAR » Wed Oct 16, 2013 8:30 pm
ON SOME MZ SCORPIONS THE RIMS WERE PAINTED ON THE INSIDE AS WELL.. THIS CAN CAUSE A LEAK AS PAINT CAN CHIP OVER TIME .. WHEN TIRES ARE CHANGED
USING TIRE IRONS .. I HAD TO REMOVE ALL OLD PAINT WITH PAINT REMOVER AND WIRE BRUSHES . TO STOP THE SLOW RIM LEAK ... CHECK YOUR TIRE WITH SOAP AND WATER AFTER CHANGING TIRES ..
ED USA
AIRMANBEAR
Re: SLOW RIM LEAK
Postby DAVID THOMPSON » Wed Oct 16, 2013 8:35 pm
i had to clean the rims and repaint the inside of my rt125 wheels
a couple years ago for the same reason
