sealed batteries
sealed batteries
Postby ericetz301 » Mon Sep 30, 2013 6:05 am
hi folks,
collective wisdom required, please.
Is it OK to fit a sealed / gel battery with my old stile dynamo charging system?
Ive heard that the more variable charging voltage / charge rate from dynamos can do damage to this type of battery.
any information would be useful.
cheers Eric.
ericetz301
Re: sealed batteries
Postby DAVID THOMPSON » Mon Sep 30, 2013 11:05 am
if it's a generator i like lead acid type batteries
if it's an alternator type either should work...
"i have never met a motorcycle that did not need a bigger battery compartment"
Postby Srinath » Mon Sep 30, 2013 3:20 pm
DAVID THOMPSON wrote:"i have never met a motorcycle that did not need a bigger battery compartment"
He he .. back when I had a high miler GS500 I pulled the airbox out and fabbed a batter box that would take any battery sitting length wise ...
I think the silly etz9bs in the MZ skorpion is just about the wimpiest out there ...
The Savage - essentially suzuki's single has a etz15 ... a 14 amp battery.
Cool.
Buddha.
Srinath
