fuel issues help...
fuel issues help...
Postby Deedum9 » Wed Sep 25, 2013 2:53 am
Hello ..me again
touch wood the MZ300 has been running fine, thus far.
i now have a starting problem, ie it wont start, but the bottom of the carb just keeps filling with fuel and seeping out ?
any ideas please ?
thank you in anticipation
I like my Hayabusa, cus it just works :(
but I like a challenge :)
Deedum9
Re: fuel issues help...
Postby therealche » Wed Sep 25, 2013 8:04 am
Either a holed float... but that usually ends up with fuel pissing out all over the place
Or a speck of dirt /corrosion in the float needle valve... carefully dismantle the valve, polish the needle well and re-assemble
therealche
Postby Deedum9 » Wed Sep 25, 2013 10:39 am
it does appear to come out of where the gasket is at quite a rate of knots ?
how do i remove the floats, have had a go but seems almost impossible.....
Deedum9
Postby therealche » Wed Sep 25, 2013 4:22 pm
Remove and clean the float valve first.
To remove the float you need to tap the pivot pin out. IIRC it only comes out one way having serations on one end. The "legs" that the pin go through are fragile so be careful, I use a pin punch and a very small hammer and arrange the carb so the leg is supported
If the fuel is coming out at the gasket, it is definitely overfilling... and you probably need new gasket. The float height may also need adjusting but we can come to that later!
( I am assuming this is a BVF carb by the way)
therealche
Postby MichaelTorre » Fri Sep 27, 2013 4:00 am
What he said about supporting the legs.x2
treat them as GLASS.
M-
MichaelTorre
