clutch tolerance
clutch tolerance
Postby MichaelTorre » Wed Aug 21, 2013 7:58 pm
.........can some one list the tolerance or dimensions for clutch run out of a ts 250 clutch.
I measured my clutch and the hub and I have to .0025 total indicated right now but I have no idea if it is good or bad .
I do want to find neutral when I run the MZ
Regards,
Michael
MichaelTorre
Re: clutch tolerance
Postby therealche » Fri Aug 23, 2013 4:08 pm
Ive looked at my manuals and can't find a figure for this. the only thing I have come across is axial play in the clutch centre ( in-out movement on the crank) which is specified as 0.05- 0.1mm (2-4thou).
therealche
