Rattling front brake etz251
Postby thomaskwscott » Tue Feb 26, 2013 9:11 am
Hi guys,
My etz failed its mot a code of weeks ago because of a leaky fork seal that dropped oil all over the front caliper. I have since had the pads changed but now there is a very unsettling rattle that appears to come from one of the pads being loose. The bike brakes ok but it's getting louder and making me very nervous, is this a known issue?
Tom
thomaskwscott
Re: Rattling front brake etz251
Postby Skorpion » Tue Feb 26, 2013 2:18 pm
thomaskwscott wrote:Hi guys,
Tom
You did replace the anti rattle spring on top of the pads.
Skorpion
Postby thomaskwscott » Wed Feb 27, 2013 4:07 am
I actually had it done by a garage but that gives me something to check this weekend..... :-D
thomaskwscott
Postby Old Dog » Wed Feb 27, 2013 5:50 am
Yep, Skorpion has is it, you have lost or miss fitted the anti-rattle spring. :D
All the best
Old Dog
Old Dog
Postby thomaskwscott » Sat Mar 02, 2013 6:09 am
Hi guys,
I just had a quick look at the spring. It is fitted correctly but seems to have enough play to allow the pads to rattle. The thing that worries me is that the rattle is rhythmic in time with the turning of the front wheel. Could this be an indication of a warped disc?
Tom
thomaskwscott
Postby Skorpion » Sat Mar 02, 2013 9:38 am
Tom
More likely something to do with the new pads or the fitting of them if it didn't do it before.
Do the pads pull back when you release the brake, no drag on the disc, if you have drag you need to clean the brake's piston's, also you could try bending slightly the anti rattle spring to put more tension on the pads.
If you are not comfortable doing it yourself take the bike back to who ever fitted the pads, and tell them you are not happy with the way they are now.
Skorpion
Postby Old Dog » Sat Mar 02, 2013 11:47 am
I had a warped disc once and you will hear it. It will be a regular binding of the brake on, then off, then on, then off schoof schoof schoof.
All the best
Old Dog
Old Dog
Postby thomaskwscott » Sat Mar 02, 2013 3:50 pm
Hi guys,
The schoof schoof schoof sound is exactly what I am hearing. In fact when I spin the wheel slowly I can see it pick up the pad, drag it then release it. This doesn't seem to affect my braking at all and the pads don't bind after braking. Unfortunately I wouldn't know if it was happening before as previously I had a broken fork seal that had saturated the pads in oil. It sounds like I'm in the market for a new disc.
Tom
thomaskwscott
Postby DAVID THOMPSON » Sat Mar 02, 2013 6:36 pm
try cleaning the disk but do not get the cleaner on the new pads
Postby breakwellmz » Sun Mar 03, 2013 2:56 am
Hi
I don`t think a slightly warped disc is reason to change it.
I take it the pads were not changed by the same garage that did the Mot?
Postby Old Dog » Sun Mar 03, 2013 5:16 am
The question is, does she stop clean or does she shudder and throw her head about.
If the former I wouldn't be too concerned, if the latter you need to change the disc.
All the best
Old Dog
Old Dog
Postby LANDSURFER » Fri Mar 15, 2013 12:07 pm
Check that one of the caliper pistons is not siezed.
The noise of a 'rattle' was caused by a single pinton sizure on my ETZ.
The working piston drives the disc into contact tith the non moving one making the 'rattling ' noise.
The road goes on forever.
To be anti war is human.
To be anti British Soldier is unacceptable.
LANDSURFER
