possible clutch adjustment help (= thank you (=
Postby franek25 » Thu Sep 06, 2012 3:24 pm
Have a kinda issue. I put new detent in and seems to stay in gear just really hard to put in gear. seems to skip 33rd for some reason. Hear grinding when put in gear. Also noticed that when clutch pulled tire spins still a little is that normal ?? I a wondering maybe i can adjust the clutch somehow besides the little nut and screw on the handle bars?? Anyone have any ideas sorry wish i new more about bike kinda learning as i go have no were else to turn )= Thank you all for al lyour help (=
franek25
Re: possible clutch adjustment help (= thank you (=
Postby radiograf » Thu Sep 06, 2012 3:51 pm
I know I'm probably stating the obvious, but have you put any oil in? Is it of the correct grade, I've had some stange gearbox/ kickstart problems with an etz251 with too thick an oil.
radiograf
Postby franek25 » Thu Sep 06, 2012 4:57 pm
Oh not offended at all I put one quart of 80 gear oil would suggest a diffrent weight or certian brand ?? Is one quart enough I only found info stating 900cc which converted to quarts is almost ! (= thnak you for your help it is much needed (=
franek25
Postby franek25 » Thu Sep 06, 2012 5:11 pm
Was there any special way i was supposed to put detent in. I keep reading , " as long as you dident shift gears with detent out you should be able to just screw bolt spring and ball back in . Well since the spring was shot and the ball was missing the gears were shifted by old owner and me loading bike in truck and putting in gear once in truck and who knows how many times by owner. I was wondering what is the issue with just screwing the bolt back in after bike has been shifted ?? because that is what i did )-= please help ??
franek25
