ETZ 251 Front caliper replacement
Postby thomaskwscott » Tue Aug 28, 2012 8:09 am
Hi Guys,
I have been having trouble with the front brake on my ETZ ever since i bought it. I remember someone saying that the caliper was a copy of a Brembo design and a bit of googling seems to show its the same as a BMW K75/K100. I am considering replacing the entire system with that from the BMW. Has anyone else attempted this?
Tom
thomaskwscott
Re: ETZ 251 Front caliper replacement
Postby radiograf » Thu Sep 06, 2012 2:25 pm
Check your brake pipe first, mine was very perished after 20 years, causing the brake to be very soft. Well worth replacing with a braided stainless teel hose.
radiograf
Postby DAVID THOMPSON » Thu Sep 06, 2012 5:38 pm
try new line of good quality and new fluid
and some of the bmw line from 80 to maybe 84 look close
look at the ones that take a ebc fa18 pads as an aftermarket replacement
front brake lamp switch is the same as some of them also
Postby dwc » Fri Sep 07, 2012 7:41 am
For what it's worth I have tried to replace the seal in my ETZ brake cylinder to no avail. It just pissed fluid everywhere. I replaced the brake line to braided and was going to replace the cylinder with an aftermarket one for a CB200.They can be purchased from WEMOTO along with the switch which I believe can be wired into the connectors in the headlight.
Regards DWC
dwc
Postby thomaskwscott » Mon Sep 10, 2012 8:37 am
Hi Guys,
Thanks for the replies. I had a careful look at the caliper over the weekend and it seems to be ok. I traced all the way up the line (i replaced this about 18months ago with a braided one) to the master cylinder and found it was still leaking despite the fact that i replaced the seals barely 2months ago. Anyone know of a replacement master cylinder for MZs?
Tom
thomaskwscott
Postby DAVID THOMPSON » Mon Sep 10, 2012 12:12 pm
take a look at this
http://www.yoyodyneti.com/ProductInfo.a ... 10.4620.23
Brembo 10.4620.23 is the Brembo number for the item
look on this page for motoguzzi use // look at 1000cc bikes
http://www.thisoldtractor.com/gtbender/ ... brakes.htm
Postby comanche91 » Tue Sep 18, 2012 2:17 pm
-Don
1-3/4 1995 Silver Stars
comanche91
Users browsing this forum: Bing [Bot] and 21 guests
