Skorpion Cush Drive
Skorpion Cush Drive
Postby basser23 » Mon Feb 13, 2012 10:07 am
How much slop is acceptable for the cush drive before replacement needed?
Chip
Skorpion Cush
Postby jimc » Mon Feb 13, 2012 2:18 pm
First check the sprocket bolts - mine loosened up slightly and it looked just like the cush rubbers were getting sloppy.
Catch it early to keep the hub from getting boogered up.
Sorry I don't have a spec. on allowable clearance on the drive....
Jim
1996 Skorpion Sport
1981 XT550 Yamaha
1989 KDX200 Kaw
1994 Duc 900cr
jimc
Re: Skorpion Cush Drive
Postby basser23 » Mon Feb 13, 2012 4:38 pm
Good point,even though my bolts are safety wired...I have(somewhere) a cush drive,just have to finde it in the mass of stuff in the shed argh!
Postby DAVID THOMPSON » Mon Feb 13, 2012 6:33 pm
?? part number for cush drive from any other bikes that will work
Postby basser23 » Mon Feb 13, 2012 6:41 pm
i've looked Dave,some yamahas come close....not perfect though,Grahams has if needed
Postby jimc » Tue Feb 14, 2012 9:12 am
It's possible still - it can loosen without the nuts backing off.
The bent over retainers on mine were still engaged.
Easily checked by watching the outer hub center / sprocket for movement when rocking it in gear.....
1996 Skorpion Sport
1981 XT550 Yamaha
1989 KDX200 Kaw
1994 Duc 900cr
jimc
Postby basser23 » Tue Feb 14, 2012 11:54 am
yep thats how I checked it...rocking in gear, a bit of slop,maybe 1/16 inch
