Turn signals doing hazard/4 way now
Postby chisleu » Mon Nov 14, 2011 5:55 pm
I had to replace my rear turn signals because I broke one but now all 4 flash at the same time (hazard lights / 4 way blinkers)
The indicator in the speedo doesn't flash. It used to always flash both, although the blinkers worked correctly.
I'm unsure what exactly I could have messed up unless I caused a short or something. I put the green wires to the wire with the stripe, although it shouldn't matter.
Maybe the bulb type is causing a problem (pulling too much juice or maybe too high resistance so it looks like a blown bulb?)
chisleu
Re: Turn signals doing hazard/4 way now
Postby DAVID THOMPSON » Mon Nov 14, 2011 6:17 pm
check you did not get the wires reversed on the one you replaced
and are the new ones wired the same inside as the old one
watch the confusion
germany for many years used brown as ground
others used green
china does it house wiring style with white as common black is hot green is the safety ground
best to take a class on how to use a volt /ohm meter
lookin for a good how to on that my self
Postby chisleu » Mon Nov 14, 2011 6:42 pm
DAVID THOMPSON wrote:check you did not get the wires reversed on the one you replaced
watch the confusion
others used green
I'll switch it but I'm guessing that isn't the problem.
EDIT: I was WRONG! :) Thanks!
Now the turn signal indicators don't work at all. I think these lights are grounded through their base as well, which would explain why they 4 way'd. There is no ground on the base so I'm going to run a ground wire from the bracket to the exhaust hanger (where my tail light ground is) and see if the indicators work properly then.
chisleu
Postby DAVID THOMPSON » Mon Nov 14, 2011 10:21 pm
take the new lamp apart and see how its wired
don't short thing out
"they pack smoke in electrical things at the factory....
when you do some thing that makes the smoke escape
it does not work any more"
quote from my dad about 1960 still true today
Postby radiograf » Tue Nov 15, 2011 4:35 pm
Had a simular problem with a Suzuki, all 4 indicators came on, and the headlamp flashed! Turned out to be a bad earth.
NOTE
bad earth = bad ground
in some country's
radiograf
Postby chisleu » Tue Nov 15, 2011 6:27 pm
Not sure what is going on with the indicator. They are flickery when they flash, and they still flash both sides together. The actual signals flash correctly so it's not a huge deal.
I'm betting I need to ground that bracket that the rear signals are mounted to.
chisleu
Postby DAVID THOMPSON » Wed Nov 16, 2011 12:22 pm
when electric does weird things
bad ground is high on list of the usual suspects
or Heaven forbid a brand new defective part
Dave
Postby chisleu » Wed Nov 16, 2011 1:44 pm
DAVID THOMPSON wrote:when electric does weird things
Dave
Yep. Man I hope it gets too cold to ride this winter. I'm kinda hoping to strip the plastics and rewire the bike. There is a lot of hackery going on with the electrical system.
chisleu
Postby DAVID THOMPSON » Wed Nov 16, 2011 10:57 pm
after working on bikes 55years i have see a lot of hacked up junk
and its getting worse.... :smt022
and the poor quality of copper wire is not helping things....
my rt125 got backed over in a parking space in mid September
and the lady hit it so hard she knocked the wires loose from the spades that hook
to relay 19 the spades were still on the relay the wires broke
good thing i still own a truck had to haul it home :smt022 non runner for 2 days
its running good but the weather is nasty here now about time to put them away for the season...
