Mounting Coil
Mounting Coil
Postby Fluffy_Dog_1018 » Sun Nov 28, 2010 1:05 pm
2001 Skorpion 660 Traveller
Hi, the OEM rubber mounts that are between the coil and the frame on my bike are completely shot to the point where the coil is barely hanging on the bike. My question is can I simply run new bolts (with the appropriate spacers) thru the frame tabs to re-secure the coil. I ask this because it seems the OEM rubber mounts are designed to isolate the coil from the frame? If I run bolts I will be grounding the two mounting tabs on the front and back of the coil to the frame. Is this allowed or will I fry something?
Thanks for your thoughts.
Somthin ain't right.
1982 Yamaha Maxim SOLD
2001 Suzuki SV650 SOLD
2001 Kawasaki Concours SOLD
1983 Honda CB650SC SOLD
1996 BMW R1100R
2001 MZ Traveller
Fluffy_Dog_1018
Re: Mounting Coil
Postby DAVID THOMPSON » Sun Nov 28, 2010 7:57 pm
not sure about the fry some thing
but it will most likely shake the coil to pieces
if it vibrates as bad as mine does
Re: Mounting Coil
Postby MZCountryRider » Mon Nov 29, 2010 9:10 am
I'm not sure how the coil is mounted on the Scorpion series. Are the mounts little rubber cylinders with studs poking out each end?
Those and many more types are available from McMaster-Carr: http://www.mcmaster.com/#vibration-dampers/=9xgiir .
Last edited by MZCountryRider on Fri Dec 03, 2010 9:15 am, edited 1 time in total.
Charlie
'69 Guzzi Ambassador
'71 Guzzi Ambassador
'72 Benelli 175 Enduro
'73 Guzzi Eldorado
'76 Guzzi I-Convert
'77 Morini 3 1/2 Strada
'81 Ducati 500SL Pantah
'82 Moto Guzzi V50 III
'97 MuZ Skorpion Tour
MZCountryRider
Re: Mounting Coil
Postby comanche91 » Mon Nov 29, 2010 8:09 pm
I doubt the coil is mounted with shock mounts to isolate it from ground. The shock mounts are there to protect it from vibration. Here's another good source for them.
http://www.vibrationmounts.com/Store.asp?Page=RFQ/VM01002.htm
On a side note, anything that was factory mounted on a shock mount was done for a reason - minimize vibration. I have no idea if the exhaust pipe/muffler was mounted on shock mounts on my Silver Star 500 as it had a kluge exhaust system on it when I got it, but when I redid the exhaust system, I added shock mounts like below where it attached to the frame. Amazing how much smoother it feels.
-Don
1-3/4 1995 Silver Stars
comanche91
Re: Mounting Coil
Postby Fluffy_Dog_1018 » Mon Nov 29, 2010 11:33 pm
Hey thanks for the feedback. I would never have thought you could source such an odd part. Ordered a couple today. Will post an update when they arrive.
Last thing I need is a bad coil because of something I did but do you think a coil would be so sensitive to vibrations that the engineers had to isolate them?... they seem pretty solid state to me (but what do I know) :?: . Thanks!
1996 BMW R1100R
2001 MZ Traveller
Fluffy_Dog_1018
