by Old Dog » Fri Oct 01, 2010 10:25 am
I will wager that it is not the switch that is leaking - a little plumber's tape is all you need there. Beside (next to) the switch there is tin plug part of the casting process. Burwins in the UK sell a turned alloy version which replace it. You then need to use a little araldite to make the seal good. Probably best to lay the bike over and degrease first. Also be sure that it is not weeping from behind the generator ie: that your crank seal isn't leaking.
Well good luck and let us know how you get on. My fix is still a good 'un after over seven years
All the best
Old Dog
