73 150 MZ how big a battery can I use.
Postby reetpleat » Thu Sep 09, 2010 11:08 pm
I just got this bike, a cool 73 150. It has a six volt battery that is tiny and it is shot. i want to put the biggest one I can in. But will a certain size affect the wiring, like burn it out or whatever? I can figure out size to still fit but don't want to meess up the wiring.
Any advice would be greatly appreciated.
reetpleat
Re: 73 150 MZ how big a battery can I use.
Postby comanche91 » Thu Sep 09, 2010 11:33 pm
You can put the biggest battery you can find that will fit in the cavity - as long as it's a 6V battery of course. I just finished installing a considerable larger maintenance free battery in my 12V Silver Star, but had to modify the hold-down hardware - no problem. So measure the cavity dimensions, then go searching for a 6V group number battery that will fit. Make note of the location of the positive terminal - you don't want that near any grounding points. :-D
-Don
1-3/4 1995 Silver Stars
comanche91
Postby reetpleat » Fri Sep 10, 2010 5:03 pm
Great. Thanks so much.
Mateo
reetpleat
