Spark Plug
Spark Plug
Postby rd400racer » Sat Sep 04, 2010 2:02 pm
I recently picked up a Skorpion racebike. It wasn't running due to bad gas so I cleaned the carb and while I was at it I changed the plug. I did not have a DPR8EA in the shop but I had a DPR9EA, which I put in. The bike fired right up. Can I hurt the engine with this plug?
rd400racer
Re: Spark Plug
Postby comanche91 » Sat Sep 04, 2010 3:07 pm
rd400racer wrote:I recently picked up a Skorpion racebike. It wasn't running due to bad gas so I cleaned the carb and while I was at it I changed the plug. I did not have a DPR8EA in the shop but I had a DPR9EA, which I put in. The bike fired right up. Can I hurt the engine with this plug?
Unlike most other plugs, on the NGKs the higher the heat range number, the colder the plug. So a 9EA is one range colder than the 8EA. The worst think that could happen is that it may foul up. Pull the plug after a few 100 miles and look at the color. Ideally it should be a tan color, not sooty black (too cold) or white (too hot).
-Don
1-3/4 1995 Silver Stars
comanche91
Re: Spark Plug
Postby basser23 » Sat Sep 04, 2010 4:46 pm
I agree with the 9 being colder,just check it as mentioned..if it is race only,it may just be perfect depending on track length etc.
Bill Jurgenson I think recommends a 7 for street use.....
Re: Spark Plug
Postby rd400racer » Sat Sep 04, 2010 8:06 pm
Thank you all for that info. I normally race RD's and RZ's, and I've had occasions where one size wrong with the plug or jet has holed a piston. I bought this bike for my son to do trackdays with, but I think it will see Clubman action in WERA. Just riding it down the street today put a huge smile on my face.
rd400racer
Re: Spark Plug
Postby DAVID THOMPSON » Sun Sep 05, 2010 5:22 pm
warning MZ = addiction you have been warned
i am up to 3 now nuff said
