Tire bead seating question
Postby Nozz » Sat Jun 26, 2010 3:02 pm
I just changed a back tire, and have one portion that the bead seems to be riding low, or inside. I've tried overinflating, strapping a tiedown around it and everything else is popping into place. Any suggestions? It happens to be the paint marked light point on the tire. Thanks!
Nozz
Re: Tire bead seating question
Postby comanche91 » Sat Jun 26, 2010 4:16 pm
Did you lube both sides of the tire bead up before inflating the tire tube?
-Don
1-3/4 1995 Silver Stars
comanche91
Postby DAVID THOMPSON » Sat Jun 26, 2010 7:31 pm
remember if its the alloy rims of the cast wheel like my saxon tour
they require tubes even though tubeless will mount up
Postby comanche91 » Sat Jun 26, 2010 9:37 pm
DAVID THOMPSON wrote:remember if its the alloy rims of the cast wheel like my saxon tour
they require tubes even though tubeless will mount up dave
They all require tubes Dave, including the Silver Star spoke wheel. That has nothing to do with lubing the tire beads when mounting. :-D
-Don
comanche91
Postby DAVID THOMPSON » Sat Jun 26, 2010 11:18 pm
did not know which wheels he had
have seen a silver star someone put the saxon tour rims on like mine has
and wanted to make sure
Postby Nozz » Sun Jun 27, 2010 12:39 am
After I posted this I went back after it with a hammer and 2x2 . I had lubed up the rim, but I went back and added more to that section and blew it up until it seated OK. Now to get it in balance... Task for another day. Thanks!
-=jn
Nozz
