oil mix ratio
oil mix ratio
Postby hotrodder » Sun May 16, 2010 5:28 pm
can anyone advise what oil mix I should be using on a mid 80's ts125 with synthetic 2 stroke premix? got no handbook with bike and its been a while...
also..how does the mixing jug under the petrol cap help the equasion..theres no marks on it so I have no idea what quantities of fuel it mixes to?
many thanks
hotrodder
Re: oil mix ratio
Postby djsbriscoe » Mon May 17, 2010 6:09 am
The mixing ratio is 50:1 thats 50ml of petrol to 1 ml of oil. Why not use a kitchen measuring jug to find out how much the cap holds? I can't remember how much they hold as It's a while since I had a TS.
David.
Electronics tech by trade.
djsbriscoe
Re: oil mix ratio
Postby breakwellmz » Wed May 19, 2010 3:21 am
Hate to put the cat amongst the pigeons BUT.I had both a Supa 5 and a 150 at the same time in the 80s,and remember them running different ratios 50:1 for the 250,and 33:1 for the 150.Check out the UK based MZ Riders(?) club for confirmation.
Re: oil mix ratio
Postby Guesi » Fri May 21, 2010 12:09 pm
Hello
You can use 1: 50 ratio without any problems...
For the ETZ 250 MZ allowed 1:100 with synthetic oil (castrol biolube for example).
1:33 was only necessary for the upper conrod bearing before they changed to needle bearing in the 70s....
GüSi
Guesi Motorradteile
MZ spare parts
Users browsing this forum: Bing [Bot] and 15 guests
