Skorpion electronic fuel injection-Just dreaming?
Postby djsbriscoe » Thu Apr 22, 2010 5:00 am
I've had a look at the Microsquirt ECU
http://www.microsquirt.info/indexright.htm
and was wondering if a skorpion could ever be adapted to use such a system. I know a fuel injection throttle body would be needed to replace the twin carb set up but could one body be used with a two into one manifold? I'm assuming that the throttle pot and mass airflow sensor is incorporated in throttle body.
Not sure what else would be required as that's as far as i've gone with my research.
I think I have too much time on my hands at the moment so I tend to daydream a bit.
Anyone have any thoughts on the subject.
David
Electronics tech by trade.
djsbriscoe
Re: Skorpion electronic fuel injection-Just dreaming?
Postby breakwellmz » Thu Apr 22, 2010 6:44 am
AND the high pressure fuel pump!-usualy incorporated into the fuel tank.
Postby iceman » Thu Apr 22, 2010 8:38 am
You would need a new ECU to read/monitor and adjust all the input parameters.
John Lennon
iceman
