Electrical/Wiring Diagram for 95 SilverStar 500?
Postby comanche91 » Sat Oct 17, 2009 4:51 pm
I've searched and searched. Found one online in German, but can not make a whole lot of sense out of it. Does anyone have a source or link for a schematic? The previous owner has been into the wiring under the seat and I'd like to get it sorted out correctly. One of the things I'm looking for are the termination points for the side stand micro safety switch.
I'd assume a similar year Saxon 500 wiring diagram might be close too? Thanks very much -Don
-Don
1-3/4 1995 Silver Stars
comanche91
Re: Electrical/Wiring Diagram for 95 SilverStar 500?
Postby DAVID THOMPSON » Sat Oct 17, 2009 9:15 pm
my saxon tour has no switch on the side stand
look at wiring harness drawing for a skorpion tour or rt125
relay 19 on the rt125 is grounded by a green wire that runs to the handlebar kill switch
and the side stand switch part of your harness is related to my rt125 the rest is like my saxon tour
and i have never seen a wiring drawing for it
looks like we are going to have fun with this ...unless some one out there has a drawing on this model
Postby comanche91 » Sat Oct 17, 2009 10:19 pm
Sure hope someone has one Dave. :(
-Don
comanche91
Postby comanche91 » Tue Oct 20, 2009 10:15 pm
Anyone?
-Don
comanche91
Postby Nozz » Tue Oct 20, 2009 10:37 pm
Nothing here either, but neither of mine have an active safety switch for the side stand (one bike has no side stand at all).
Nozz
Postby comanche91 » Tue Oct 20, 2009 11:03 pm
Nozz wrote:Nothing here either, but neither of mine have an active safety switch for the side stand (one bike has no side stand at all).
Thanks Nozz. My side stand switch has been bypassed too obviously, as the switch arm was bent out of the way, not closing the switch, and it still starts fine. I'm slowly translating the German SilverStar wiring diagram I have, and it looks like I'll be able to use that to sort out the buggered wiring I have under the seat.
-Don
comanche91
Postby djsbriscoe » Wed Oct 21, 2009 3:10 am
Why not post the diagram (or link) you have here? Someone who speaks German could maybe help you translate it. And if someone else is looking for the diagram they'd find it here. It can be posted in the gallery or inline to one of your topic posts.
David.
Electronics tech by trade.
djsbriscoe
Postby comanche91 » Wed Oct 21, 2009 11:13 am
djsbriscoe wrote:Hi,
Why not post the diagram (or link) you have here? Someone who speaks German could maybe help you translate it. And if someone else is looking for the diagram they'd find it here. It can be posted in the gallery or inline to one of your topic posts. David.
Excellent idea David, here it is. It's difficult translating the technical terms through the online translators. I've started editing some of the German in RED. If any of our German friends want to give it a go I also have an unedited copy I can send. Danke!
-Don
comanche91
Postby manumensa » Wed Oct 21, 2009 6:59 pm
(7) Front left-hand turn signal.
(8) Front right-hand turn signal.
(9) Ignition HT coil.
(10) Spark plug.
(12) Turn signal relay.
(16) Taillight
a) Stop lamp bulb.
b) Tail lam bulb.
(17) Rear left-hand turn signal.
(18) Rear right-hand turn signal.
(24) Horn.
(25) Starter relay.
Saludos/Regards
manumensa
Postby comanche91 » Wed Oct 21, 2009 7:48 pm
Manumensa, muchas gracias mi amigo!
-Don
comanche91
Postby nikitino » Fri Oct 23, 2009 7:33 pm
I have the wiring diagram for Country 500 in english. Not sure how to post a picture of it though......If someone can tell me how, i will try. Either that or i could translate some of the one here.......
nikitino
Postby comanche91 » Fri Oct 23, 2009 8:01 pm
PM sent nikitino.
-Don
comanche91
Postby DAVID THOMPSON » Tue Jan 16, 2024 5:51 pm
USE OF PHOTOBUCKET TO SEND PICTURES TURNS A POST IN TO A WASTE WHEN IT ALL GETS ERASED
Postby Blurredman » Thu Jan 18, 2024 3:52 am
Photobucket turns to paid subscription probably 10-15 years ago. I used it a lot back in the late 2000's. But, all those who didn't subscribe and or re-locate their albums to other sites and change the links will have broken images. :cry:
