Does anyone know if the Skorpion upper frame cross member (the 50 mm tube) connectsthrough into the side franme tubings (i.e can fluid follow between the frame tubes in this upper menber). I know it can through the lower cross tube.
Planning a Skorpion "oil in frame" modification.
Doug
