Saxon series front brake rebuild kit cross ref?
Postby 95SaxonTour » Sat Aug 29, 2009 10:25 pm
Does anyone know what common bike that this front
caliper is from. I need a rebuild kit and have a feeling
that MZ "borrowed" this front brake set up from some
other larger manufacturer. BMW possibly?
Ryan
95SaxonTour
Re: Saxon series front brake rebuild kit cross ref?
Postby MZCountryRider » Sat Aug 29, 2009 11:30 pm
Yes, the caliper is actually a Brembo item as used on BMWs, Moto Guzzis and others. I never measured the piston to see which size/type it was - an F08 or F09. The difference is 38 mm vs. 48 mm pistons. It's most likely the F08, not the much less common F09.
Here's a link to my Guzzi parts supplier with just about everything you could want:
http://www.mgcycle.com/index.php?cPath=110_115
And then there's TAW also: http://www.tawvehicle.com/brembo_F08_P108_parts.htm
Hope this helps.
Charlie
'69 Guzzi Ambassador
'71 Guzzi Ambassador
'72 Benelli 175 Enduro
'73 Guzzi Eldorado
'76 Guzzi I-Convert
'77 Morini 3 1/2 Strada
'81 Ducati 500SL Pantah
'82 Moto Guzzi V50 III
'97 MuZ Skorpion Tour
MZCountryRider
Postby DAVID THOMPSON » Sun Aug 30, 2009 1:57 am
ebc fa18 i think many bmw models for the pads
below list from ebc may help sort out what fits from other bikes
click on picture site crops it till you click
