'74 TS 250 Chugs when I let off on accelerator
Postby matthewjames » Fri Aug 07, 2009 4:53 pm
Hi Folks:
I've got a nice TS 250 that starts and runs great, but when I'm driving and I let off on the accelerator, the engine pulses and chugs causing a slightly herky-jerky ride. I usually correct for this by giving it a little bit of gas to smooth things out, but this is not a perfect solution. Any idea what might be going on here?
Cheers,
Matt
matthewjames
Re: '74 TS 250 Chugs when I let off on accelerator
Postby djsbriscoe » Fri Aug 07, 2009 5:01 pm
Try changing the needle position in the carb either 1 notch up or down.
David.
Electronics tech by trade.
djsbriscoe
