TS 250/1 - slow flashing turn signals
Postby Gentle Giant » Wed Aug 05, 2009 1:50 am
I know that having turn signals that flash weakly (or even weekly!) is not a new phenomenon, but I was wondering what solutions you may have found to obtain the best improvements. :|
I've bought a new set of 6v flasher bulbs and a new flasher relay and will replace them shortly.
A visual check of the lamp ground/earth points seem to suggest that all is OK (ish) but i could be wrong.
Is it worth adding new ground/earth leads anywhere?
Any help, advice or guidance gratefully received!
Thanks!
Safe roads, folks.
:D
1978 TS 250/1 Supa 5 (now sold)
1992 MZ ETZ 251 Luxus
1982 Jawa 350 Model 634 (with a 638 engine)
2009 Derbi Terra Adventure
1992 Kawasaki GT550
Gentle Giant
Re: TS 250/1 - slow flashing turn signals
Postby tonyc » Sat Aug 22, 2009 5:45 pm
How many volts does the bike actually produce? It may be that there is a shortage of electricity! Does the battery charge ok? Are the other lights dim?
tonyc
Postby MrBoo » Fri Oct 09, 2009 6:32 am
Slow flashing indicators is usually a sign of not enough current.
I have a Lotus Elan which has a glass fibre body. The indicators were flashing very slowly. I connected a test meter to the outside of the bulb holder =the earth side and found a voltage of 2 or 3 volts when the bulb was illuminated. This is a symptom of poor earth: part of the voltage is being used to overcome the electrical resistance in the wires connecting back to the battery negative terminal.
Solution: I cleaned all connections and added an extra wire to connect the bulb holder to the car chassis. This reduced the electrical resistance for the current going back to the battery.
When my daughter bought an MZ251 there was a large red wire from the battery positive terminal but a tiny black wire from the negative terminal to the bike frame. People forget that the same current has to flow in each terminal. I fitted a larger diameter black wire to earth the battery.
MrBoo
Postby Gentle Giant » Fri Mar 05, 2010 11:54 am
Somewhat belatedly, that is actually what I ended up doing, namely clean up the connectors and ensure a good earth. The flashers then worked very well indeed. Job done!
I have now sold the TS250/1 to my friend and have replaced it with an ETZ251 which was in need of some TLC. No doubt I'll have some questions as the restoration progresses.
Cheers!
1992 Kawasaki GT550
Gentle Giant
Users browsing this forum: Bing [Bot] and 187 guests
