rt kill switch
rt kill switch
Postby robert mack » Mon Jul 27, 2009 4:33 pm
right, now i never use the kill switch, but tonight i flicked it by mistake and the bike never cut out.
i tried it a few times but i seems not to be working.
does anyone have any idea why before i strip the controls?
all the best
robert
British by birth,Scottish by the grace of God.
robert mack
Re: rt kill switch
Postby DAVID THOMPSON » Mon Jul 27, 2009 9:35 pm
try the bike running
kill button in run position
pull clutch lever in
put bike in gear
put side stand down
does bike die ?
both sidestand and kill switch work with
diode 31 it may be bad (open or shorted ??) it is in wiring harness
exactly where it is i do not know
and have not had time to wire up a test circuit and play to see what it really does
but it does make the green wire at relay 19 do its thing and disrupt power
or relay 19 is sticking ????
it is on the frame near the minus post of battery on an rt
i would clean up the handle bar switch and see that it has a proper ground
before digging elsewhere
Re: rt kill switch
Postby robert mack » Thu Jul 30, 2009 5:25 pm
Hi david
side stand switch has been removed already (not by me) so changed relay 19. all is well for now
robert mack
