are special yam tools required for adjusting the valves
Postby iktank » Fri Jun 12, 2009 4:01 pm
660 engine - due for the valves to be checked and will need adjusting
I do not have the yamaha valve spannes can i adjust the valves with normal open end and ring spanners, and normal feeler gauges.
if i can use normal spannes what size.
many thanks if someone can advise
iktank
Re: are special yam tools required for adjusting the valves
Postby djsbriscoe » Sat Jun 13, 2009 4:09 am
Here is the procedure from the xtz660 service manual
Yamaha_XTZ660_ValveAdjust.pdf
(1.75 MiB) Downloaded 272 times
HTH,
David
Electronics tech by trade.
djsbriscoe
Postby iktank » Sat Jun 13, 2009 5:10 am
David ta for reply, what i am after is are the yam valve adjusting tools needed or can the valves be adjusted with normal spanners
If so what size spanners are needed.
I have normal open ended spanners
ring spanners both straight and the z shaped ones
ratched ring spanners
regards
Ian
iktank
Postby Norman Wade » Mon Jun 15, 2009 5:36 am
Hi Ian, You don't need any special tools for adjusting the valves in the 660 engine. The lock nuts will require a 10mm ring spanner, and the adjuster has a 3mm square end. As 3mm open ended spanners are quite rare, you could make one out of an old B.A. (British Association) spanner filed out to 3mm. Alternatively, as the adjusters aren't very tight, you could make a spanner by filing a 3mm wide slot in the end of a strip of steel. Most people I know just turn the adjuster with a pair of narrow nosed pliers, if you're careful it should be OK. :shock:
I've used a useful valve adjusting tool bought from a German firm called Kedo. http://www.kedo.de/ They do a lot of bits for Yamaha singles, adjusting tool (Spezial-Ventileinsteller) is part no: 30220, price 9.95 euros. Worth buying as it makes the job easier and avoids damaging the adjuster.
On the Skorpion, adjusting the inlets is easy enough, but the exhausts are a bit more fiddly. There's not much space and some people drain and remove the radiator to make it easier. However, it can be done without doing this, but you'll need to bend your feeler gauge 90 degrees to fit it in. I also cut down a 10mm ring spanner to make it easier.
I'm not sure how easy this is on a Mastiff or Baghira. (No doubt someone will let us know!)
So to answer your question: you'll need a short 10mm ring spanner, a 3mm open ended spanner (or equivalent), and a set of feeler gauges. The jobs a bit fiddly, but it'll be easier next time! :lol:
Norman
http://www.mzskorpion.net
Norman Wade
Postby iktank » Wed Jun 17, 2009 2:52 pm
many thanks for that, just what i needed to know, will make my own 3mm spanner. Didnt fancy taking panels, tank off etc just to fing i did not have tools required
Many thanks again :D
Ian
iktank
