MZ Skorpion keeps jumping out of 2nd gear
Postby NaPeZ » Mon Apr 27, 2009 2:38 pm
hi, i recently brought a 1998 MZ Skorpion but I've found that it jumps out of second into neutral when im flying with the throttle wide open :cry: . is this a sign of a dying gear box or is it just one of those things?
Mz Skorpion Traveller
NaPeZ
Re: MZ Skorpion keeps jumping out of 2nd gear
Postby netguz » Mon Apr 27, 2009 3:15 pm
Streuth, you´re lucky!
Shortly after I bought mine it started dropping out of 2nd straight into 1st!
When I had a look the short arm on the output shaft was loose and the rose joints were none too smooth.
I tightened up the lose bit and oiled the tight bits and since then no probs.
I hope your cure is as simple.
netguz
Postby NaPeZ » Tue Apr 28, 2009 3:42 pm
what do you mean by the short arm on the output shaft? pics would be cool im relatively inexperienced cheers
NaPeZ
