Baggy rear brake problem
Postby scholsey » Sat Mar 21, 2009 1:02 pm
Once again I am looking for some help or advice, I think the rear brake cylender has blown ... this is the grey metal part that the foot brake connects to to pump the fluid to the rear caliper. It is leaking slightly and wont pump the fluid to the caliper. I have disconnected the brake hose at the caliper end and its justs spits a little but does not have a continued pump of fliud. Are these able to be fixed or where would I get one from ? or what boke is this part compatable with ?
Just had it MOT 'd and taxed but now cant ride it ....................................
Andy
scholsey
Re: Baggy rear brake problem
Postby hutchy » Sun Mar 22, 2009 3:27 pm
you might be able to get a seal kit from grahams to fix the problem or even a replacement master cylinder, but if you have no joy with that you could always try a local breakers, you could probably graft a yamaha part on without too much trouble, say a fzr 600 or 350 lc.good luck......Hutchy
hutchy
Postby scholsey » Mon Mar 30, 2009 11:10 am
Many thanks got a Brembo cylender from a KTM 640 LC04 and it fits and works a treat so I'm back on the road ....
scholsey
Postby DAVID THOMPSON » Tue Mar 31, 2009 8:14 pm
ktm 54513101044 may be it
this fits duke 640
about 90 usd ? use mz push rod
