changing brake pads on 2003 baghira
Postby nopantsflyer » Fri Jan 02, 2009 6:42 am
can somebody tell me how i change the brake pads on my baghira?, do i have to take them off? and what screws do i have to undo, thx, michael
nopantsflyer
Re: changing brake pads on 2003 baghira
Postby nopantsflyer » Sat Jan 03, 2009 10:19 am
nobody?
nopantsflyer
Postby rodge70 » Sat Jan 03, 2009 11:02 am
never had to do this yet,though seems straight forward enough,remove caliper from forks,looks like two pins hold pads in place undo these and pads should come out,push pistons in slightly then fit pads and pins,job done.
please bare in mind i have only quickly looked at my bike and comon sense should always be the order of the day,good luck.
good idea to clean every thing and make sure what needs to slide,slides.
rodge70
Postby nopantsflyer » Sun Jan 04, 2009 8:01 am
did it yesterday, you are absolutly right, take out the two middle pins, were hard to remove, had to use an impact wrench, and change the pads, used some copper grease on the smooth part of the pins, showed already some corrosion there, works fine now, thanks, michael
nopantsflyer
Postby edec » Sun Jan 04, 2009 11:57 pm
Nopantsflyer, How many miles did you get from your pads and which ones did you replace them with?
Thanks, Ed
01 Baghira
99 Ducati SS750
edec
Postby nopantsflyer » Mon Jan 05, 2009 9:35 am
can't tell you the mileage, just got the baggi and it needed new pads, front:FA177 EBC Disc Pad set, rear: FA173 EBC Disc Pad set , the rear pads are a tight fit, michael
nopantsflyer
Postby kman.45 » Tue Jan 06, 2009 8:14 am
Hey nopants, where are you located? just wondering..
kman.45
Postby nopantsflyer » Wed Jan 07, 2009 8:11 am
naples, fl
nopantsflyer
