New member + inline oil filter location query
Postby PhilD » Sun Oct 12, 2008 12:40 pm
First post. Never had an MZ before but from what I've read these models seem to be good bikes.
I've just bought a 1995 Skorpion Sport which has been standing idle for some time. Having read some of the posts here regarding oil changes etc I decided to do an oil change and general checkover on mine before i start riding it.
Changing the oil filter was fine but I'm unclear where the inline filter/strainer is located on mine. I've followed the oil feed pipe down the frame from the tank until it joins the crankcase behind the starter motor via a flat plate with an Allen key in each side. Is this the location of the inlinefilter/strainer?
Many thanks,
Phil
PhilD
Re: New member + inline oil filter location query
Postby DAVID THOMPSON » Sun Oct 12, 2008 8:42 pm
i think your looking for number 3
left click on picture to see full view site crops it till you click on it
660oil plug1.jpg (98.48 KiB) Viewed 1716 times
Postby Linegeist » Wed Oct 15, 2008 4:27 pm
Hi Phil,
Just spotted this, sorry.............. :cry:
You should also remove the coarse filterscreen and clean it if necessary. This is in that hefty fitting just behind the starter motor and up behind the air filter housing/battery tray. It is in the continuation of that Line leading to the fitting next to the drain plug.
HTH
Bob
Linegeist
