Baggy Aluminum Swingarm - Shift lever adjustment
Postby Randew2U » Fri Sep 03, 2004 11:41 am
Has anyone seen an aluminum swingarm switchout for a Baggy. Talk about weight savings! Ebay is a constant source of aluminum from older bikes being parted out. Wish I knew if MZ morphed the geometry from another production bike.
I dont like the position of the shift lever on my foot and wonder if it is customary to adjust it to fit the rider. I'd like to move it down a bit so that it is easier to get on top of? How about the rear brake lever as well. I wonder if there is an expert bike site that talks more about fitting (adjusting) the bike to the rider? any ideas appreciated.
Randew2U
Postby boysie » Fri Sep 03, 2004 1:41 pm
The Swingarm IS ally, and the shift lever is adjustable via the threaded linkage....
boysie
Postby keithcross » Fri Sep 03, 2004 2:10 pm
So is the rear brake lever, via the adjusting screw n the operating rod and the cam stye return stop.
Postby Randew2U » Fri Sep 03, 2004 4:25 pm
hard to believe they painted over aluminum instead of clearcoat. Thanks for the advise, any guidelines on adjustment Keith?
Randew2U
Postby keithcross » Fri Sep 03, 2004 6:06 pm
Its easy to adjust the rear brake, just a matter of balancing the adjustment on the brake operating rod to postion the operating point either later or earlier in the levers travel and the aluminium cam to postion the upper point in its travel.
Adjusting the gear lever position is done by adjusting the length of the tie road between the lever and the arm connected to the gear shaft comming out of the gearbox.
swing arm
Postby DAVID THOMPSON » Sat Sep 04, 2004 3:33 pm
hello
for the swing arm try this bunch
http://www.metmachex.co.uk/
they may make it it just may not be listed on there web site
:smt006
