starter clutch
starter clutch
Postby vitesse7749 » Thu Jun 19, 2008 6:44 pm
Has anyone attempted a rebuild on the failed starter clutch that seems to plague some 125s and others? :D
vitesse7749
Re: starter clutch
Postby DAVID THOMPSON » Fri Jun 20, 2008 9:38 am
the part is not repairable
if the part becomes Unobtainum or NLA
i plan to see if i can come up with a homebuilt fix for it
the secret to its long life is lots of fresh clean oil
and DO NOT try to stop the bike when going backwards with engine off with the clutch
you will pop it ever time
also always start bike in neutral to reduce load on the sprag clutch
Users browsing this forum: No registered users and 217 guests
