MZ125sx brake fluid
MZ125sx brake fluid
Postby 67kev » Sun Jan 13, 2008 8:18 am
Hi, i'm doing some work on a friends son's MZ 125 SX (52 plate). Had to open up both of the hydraulic brake systems,(front and rear) and gonna re-fill / bleed, but don't know what spec (DOT 3, 4 or 5) fluid it has in at present. Can i just top up with DOT 3 or 4, or could it be the silicon based DOT 5? Anyone know what type they are factory filled with and also if a front master cylinder repair kit is available? Cheers 67kev.
67kev
Re: MZ125sx brake fluid
Postby DAVID THOMPSON » Sun Jan 13, 2008 4:15 pm
hello
top of master cyl on front says dot 4 only you can only hope the guys before you can read
parts book down load from here
http://www.grahamsmotorcycles.com/graha ... 0RT125.htm
what you are looking for is in the rt125 chassis parts book
PDF pages 34 and 35
order from here
i force fluid from the bottom up with a pump seems to bleed better
and on the rear the whole unit can be removed as a unit an hung from the overhead
bubbles flow up better than down
push the brake pucks all the way in and force fluid in from bottom
remove the old bad from the top resevior
it a pain mine still has air in it from 2 bad brake lamp switches
ar dave
post your location so we know where to send you for help and spares
Postby 67kev » Mon Jan 14, 2008 2:32 am
Thanks for the fast and comprehensive answer...ur right, i should have read the cap!! :oops: DOT 4 it is then! Cheers for the downloads m8. PS i'm in Suffolk UK, Kev.
67kev
Users browsing this forum: Google [Bot] and 14 guests
