Great Caliper Information/ Other MUZ modification web site
Postby droy » Sun Sep 09, 2007 12:53 pm
Folks,
Found this site
http://www.motowheels.com/italian/mypro ... i%20Brakes
It has great info on Brembo calipers ( some of which are a direct replacement to the Gimeica front ( 40 mm between bolts) and rear). Prices look good, $75 for a new brembo goldline rear caliper. They even have bracket which appear to allow you to fit the newer Brembo 65 mm bolt calipers to the 40m bolt pattern like on the MZ.
I also found this - very nice if I knew German - Bill?
http://shortfender.schnongse.de/index.php?page_id=10
Doug
droy
Postby Bill Jurgenson » Mon Sep 10, 2007 2:16 am
that is Ronald Prinz's page. He is a really nice guy but he is not a dealer and has learned a lot from me. You can write to Ronald in English. but why don't you simply ask me.
75$ is OK but not cheap for a Brembo rear caliper.
You can regularly get this stuff off eBay for a good price. Here is some:
http://cgi.ebay.de/Brembo-Bremszange-und-pumpe-Ducati_W0QQitemZ270164049764QQihZ017QQcategoryZ49792QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
http://cgi.ebay.de/Ducati-KTM-Guzzi-Cagiva-Bimota-Brembo-oro-Bremszange_W0QQitemZ110166175954QQihZ001QQcategoryZ49792QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
http://cgi.ebay.de/Brembo-Handbremspumpe-PS16-Ducati_W0QQitemZ270164049745QQihZ017QQcategoryZ49792QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
http://cgi.ebay.de/Aprilia-RSV-Mille-Brembo-Bremspumpe-mit-Bremshebel_W0QQitemZ330164256293QQihZ014QQcategoryZ78409QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
there's lots of it!
And I have a couple of 40mm Brembo calipers here that can go...
Run the Brembo clalipers with Carbon Lorraine SBK or C43 pads an a cast iron rotor and you'll have all the stopping power you ever wanted and more...
[urlhttp://www.carbonelorraine-moto.com/e_motos.htm[/url]
Of course there is a bracket to mount the newer 65mm fronts but the normal one of those is not as good as the 40mm style which easily replaces the Grimeca junk. The newest style 65 is the one to get if you really want stopping power. Overkill except for racing: the Skorpion is at least 100kmh too slow to warrant anything like that. Or the expense.
And then then there is the ABM caliper if you REALLY want that hi-tech stuff which has the standard 40mm bolt pattern ans uses the same small individual pads and the latest Brembo radial clamp.
Both are CNC milled so-called monobloc calipers, not diecast stuff.
I use this one on the racer, but only because I am an ABM dealer and get a slightly different price...
To upgrade the usual 40mm Brembo, you have only to exchange the pad retaining pin with a M6 bolt, cutting the M6 thread in the back half and adding a counternut at the back. The bolt is just snugged and countered. It is a BIG improvement, keeping the width constant under all conditions. An old trick with racers.
And that is the problem with the usual 65mm Brembo; the unsupported length is too great and there is no way to strengthen it.
The newest "cheap" cast model has, like the ABM CNC shown above, a bolted bridge in the center.
People seriously running not quite new Ducatis on the track change to this caliper.
Re: Great Caliper Information/ Other MUZ modification web site
Postby RiverDrive » Thu Nov 22, 2007 9:46 pm
Bill, do you know of any specific bikes that use the 40mm caliper?
01 Sport Cup Gone Sport
RiverDrive
Re:
Postby pillar33 » Sat Jun 28, 2008 11:07 pm
hey whats up im trying to get fairings to my 05 baghira would u happen to have any good contacts i would aprecciate the link
Bill Jurgenson wrote:that is Ronald Prinz's page. He is a really nice guy but he is not a dealer and has learned a lot from me. You can write to Ronald in English. but why don't you simply ask me.
there's lots of it!
pillar33
Postby cat » Tue Jul 08, 2008 3:00 am
Kindly stop posting all over the place about your freakin fairing. You didn't have to quote the whole post about brake calipers. Do you really think you're more likely to get some information by asking repeatedly all over the board? You're more likely to irritate people. PS: Have you ever heard of punctuation.
cat
Postby scout18 » Thu Sep 04, 2008 8:43 pm
Punctuation? You guys kill me. Bill is there anything you don't know?
scout18
Postby Grahamgfr » Fri Oct 03, 2008 6:40 am
I'm interested in upgrading my front brakes on the Baghira and was wondering if this would be an option ?
http://cgi.ebay.co.uk/Cagiva-Mito-125-E ... 286.c0.m14.
Thanks !!
above link no longer works
moderator
Grahamgfr
Users browsing this forum: No registered users and 244 guests
