Baghira spark plug
Baghira spark plug
Postby edec » Tue Sep 05, 2006 7:17 pm
Anyone change their sparkplug on a Baghira; did you have to remove the fuel tank or radiator to access it?
edec
Postby edec » Sat Sep 09, 2006 1:17 pm
About how many miles/years should the sparkplug last, thanks.
edec
Postby keithcross » Sat Sep 09, 2006 7:27 pm
I use the spark plug spanner supplied in teh standard tool kit. I dont have to remove anything apart from disconnecting the HT lead.
Postby Wonky » Mon Sep 18, 2006 4:32 pm
No i never have a problem removing plug either. You can locate it without any removal of other parts. If you start experiencing mis-firing then check the plug if it looks shot then replace it. :wink:
Wonky
