Oil leak
Oil leak
Postby Robmzetz » Tue Dec 28, 2021 3:19 am
Hi all. Sorry if this has been asked before. I have an etz 251 with a gear oil leak. It is leaking from the output shaft. My question is can I change the seal by removing the sprocket or is it a more in-depth operation? Thanks in advance.
Robmzetz
Re: Oil leak
Postby Puffs » Tue Dec 28, 2021 5:33 am
Re: Oil leak
Postby Robmzetz » Tue Dec 28, 2021 5:50 am
That's brilliant. Thank you very much. I had visions of major surgery. Hahaha
Robmzetz
Re: Oil leak
Postby Puffs » Tue Dec 28, 2021 6:50 am
Re: Oil leak
Postby Robmzetz » Tue Dec 28, 2021 7:23 am
Ah. I see. I am sourcing a seal but meanwhile I'll have the sprocket off and have a look. Thanks very much.
Robmzetz
Re: Oil leak
Postby DAVID THOMPSON » Tue Dec 28, 2021 5:42 pm
there is a very thin ring that fits a machined sprocket that makes a fit finish
for your seal to run on// ask the guys at a good bearing shop
heat the ring make sprocket very cold drop it on
Users browsing this forum: No registered users and 155 guests
