oil line diameter
oil line diameter
Postby buell1965 » Mon Oct 11, 2021 3:56 am
hi fellas , nicked my oil line that comes from the bottom right of oil tank to bottom left of engine (its the line that terminates with the two allen head bolts at the end of the metal section ) , the nick is on the upper section on the rubber line itself and not the lower metal section . I havent had any luck finding a replacement and may be forced to hose clamp a connector in and was wondering if any one knew the inside diameter . best regards from north ga
buell1965
Re: oil line diameter
Postby buell1965 » Mon Oct 11, 2021 5:54 am
Didnt mean to sound lazy its that I haven't pulled the hose and if any body knew I could pick up the adapter on the way home .
buell1965
Postby buell1965 » Mon Oct 11, 2021 12:14 pm
I probably should have mentioned it was a 95 skorpion , and it looks like a double Male brass hose mender is gonna do the trick ..cheers
buell1965
