The misery continues
Postby JawasandMZs » Mon May 24, 2021 7:25 am
My excitement about my coil was premature. I added petroil, kicked it and .... nothing. Spark, check. Compression, check. Fuel, check.
Dead. Not even backfiring or kicking back.
I know fuel is getting thru because the plug is soaked. I keep taking out to wipe it.
Baffled.
Gutted.
JawasandMZs
Re: The misery continues
Postby Puffs » Tue May 25, 2021 5:38 am
Postby Kruh » Tue May 25, 2021 7:59 am
Also check for any leaks.
A bad crank seal can have the same sympthoms - plug wet, but no start.
Kruh
Postby Blurredman » Wed May 26, 2021 12:11 am
Put a flame on the spark plug to burn off petrol.
Wirebrush it and sand the contacts.
And do as the above have said to get rid of excess fuel in CC.
Postby Puffs » Fri May 28, 2021 3:39 am
So, Tom, has the sun come out?
(=does it run again?)
