Skorpion Aftermarket?
Postby idahoduk » Fri Oct 21, 2005 8:08 pm
What have you guys been doing to your bikes. I'm more interested in suspention and aftermarket fairings then I am engine mods. Alouth anything will help. I've had some trouble finding aftermarket parts for the MZ I'm planning on buying. I've heard of guys using R6 forks and honda fairings. Sounds interesting. If you have any links I'd definatly be interested in killing a few hours at work. Thanks
idahoduk
Postby F0ul_Oli » Sat Oct 22, 2005 4:47 am
check out the racing series - anything that does work will be on a bike there!
look up mono racing on google - it might help!
F0ul
F0ul_Oli
info
Postby DAVID THOMPSON » Sat Oct 22, 2005 11:24 am
try using the search feature in the site header
there is a lost of stuff posted on the site
:D
Postby whysub01 » Wed Nov 23, 2005 8:33 am
Look at http://www.supermono.co.uk
Lots of advise can be gleaned from there. Thjere are some race fairings available for the Tigcraft frames, and easily adapted to take lights etc-one or two are above average quality for race fairings. Some second hand stuff is available too, if you don't mind doing a few repairs.
You can also find out which swing arms/forks/wheels etc can be made to fit too.
I'm going the otherway with mne-stock looking, but with a tuned motor and sorted stock (or near stock) suspension.
whysub01
Postby Gary K. » Fri Dec 16, 2005 9:04 pm
see "For Sale" section under "Parting out 02 Skorpion" :)
Gary K.
body parts
Postby Chris Hunsicker » Fri Dec 23, 2005 7:14 pm
Beasley has good fiberglass stuff:
http://beasleycomposites.com/
The Skorp stuff is at the bottom of the Ducati section. The tail section would require considerable modification for street use, and requires a good bit of creativity for mounting even for track use.
Here's two pics of the tail section and fairing:
http://philadelphiariders.com/gallery/album43/P8010099
http://philadelphiariders.com/gallery/album43/P8010092
Penske makes very good shocks for Skorps, I went with the Wilbers route:
http://wilbersusa.com/wilbers/index.htm
Penske does not exist in Europe to my knowledge, and so Wilbers is what the racers on the German site http://www.mzskorpion.de use. They are competative in price to the high-end Penske, but I think are more beautifully finished.
I haven't done any mods to the motor, and don't have any planned. I tried to make my Sport as light and nimble as possible, and am down to 346 pounds.
Chris, Philadelphia
Chris Hunsicker
