Interchangeable parts - a list
Re: Interchangeable parts - a list
Postby cat » Mon May 18, 2009 2:02 pm
Which bike does it fit? The Baghira?
cat
Postby BRAAAP ! » Mon May 18, 2009 2:23 pm
Sorry forgot to put that, yep the baghira, the 97cm long works but is a bit short, better for the slightly longer 105cm would be a better choice. .
two wheels good, four wheels bad. . . .
BRAAAP !
Postby cat » Mon May 18, 2009 2:47 pm
That's useful, I seem to remember that the OEM speedo cables often break. I see that fits a whole lot of Yamahas, so...an alternative for people not in the UK would be to get an Yamaha OEM cable for one of those bikes.
List of bikes they fit: http://www.startright.co.uk/index.php?main_page=product_info&products_id=7577
cat
Postby m4panther » Thu Sep 17, 2009 9:37 am
I replaced my headlight on my Black Panther with a KTM 502.11.510.000
does anyone know where i can get a CHAIN SLIDING GUARD for the swingarm? wore mine thru >( should have replaced that stretched chain. What about front and rear sprockets?
2001 Black Panther
2004 1000s
m4panther
Postby russ » Wed Nov 18, 2009 12:20 am
i do not know what i am doing here but can anyone help me? i am looking for an interchangeable clutch cable for my 2001 baghira from any other bike.
russ
Postby bikeseamus » Fri Dec 11, 2009 12:47 pm
I upgraded my rear master cylinder on my 2003 Traveller with a GSXR unit from a 2000 750 model with little sweat... the year might be wrong, but I think it's right...got it from a yard, and it's a Brembo unit.
Much mobetter now, and cheaper as well.
GSXRs hit the yards at an alarming rate of speed, and sometimes literally.
yuk yuk
ahem... anyway, it works beautifully and thought I would share the info.
Bikeseamus
bikeseamus
Postby rnbltt » Mon Jan 18, 2010 5:38 pm
Does anybody know if theres an interchangable rear brake light switch for the traveller.
rnbltt
Postby Skorpion » Fri Mar 19, 2010 1:40 pm
Skorpion rear brake light switch.
BMW F650 93-97 M10x1mm thread
Skorpion
Skorpion
Postby J-Ball » Tue Jun 08, 2010 2:11 pm
I've learned that the HEADLIGHT on a SKORPION TOUR is not the typical 7" round motorcycle light. I'm 97% sure that lights from Yamaha SR, SRX, Diversion etc do not fit. My Skorp Tour is a 2000 model and the light measures right at 7&1/4 inches across. My .02 cents.
J-Ball
J-Ball
Postby flintham » Thu Jul 01, 2010 5:43 pm
F0ul_Oli wrote:I was thinking how nice it would be to have a list of stuff, designed for other bikes, that fit the MZ range ( In interested in the Baghira, but lets make the list for everyone)
So far, I know the engine is a Yamaha 660cc and all the normal service parts fit.
The front disc is a Yamaha R1/6 model -99 - are the calipers also from this bike?
The front mudguard is a KTM model, but I don't know which bike!
The Rear brake Cylinder is also a KTM but which model?
What about the clocks? Did someone say they were from a Husky?
It seems to me the only bit which you can only get from MZ is the frame!
If we all put down our words of wisdom, we could edit the whole thread at the end and create a document for easy reading - what do you think?
sounds good 2 me m8 i,ve just got myself a 660 mastiff and ant got dam clue wot bits i can use insted of mz parts could u help me. im finding it very hard 2 find a rear caliper could u let me no wot else i could use other then genuin mz parts
regards rich
flintham
Postby billr » Thu Jul 01, 2010 6:18 pm
Radiator fan switch for Skorpions:
BWD TFS544
I bought one online from Advance Auto Parts.
Also look for a NAPA Echlin FS198, same part as the BWD.
Just installed and it works as it should.
Bill R.
billr
Postby cat » Fri Jul 02, 2010 4:55 am
flintham wrote:sounds good 2 me m8 i,ve just got myself a 660 mastiff and ant got dam clue wot bits i can use insted of mz parts could u help me. im finding it very hard 2 find a rear caliper could u let me no wot else i could use other then genuin mz parts
This might help (download the attached html document.):
http://www.mzriders.com/viewtopic.php?f=20&t=1370
The rear brake caliper... http://www.mzriders.com/viewtopic.php?f=20&t=2109&start=0
There would probably be some Japanese bike calipers that would fit. Have you got the original one? I think the main thing would be the mounting holes on the caliper, then the distance/offset from the mounting to the disc... which can be adjusted with spacers/washers if it is less.
cat
Postby flintham » Fri Jul 02, 2010 10:55 am
can any1 please help me i,ve just bought an mz 660 mastiff and carnt get a mz rear caliper 4 it from anywere could some 1 tell me if there is another rear caliper off a differant modal bike that will
please help regards rich flin
flintham
Postby kurtc875 » Wed Oct 20, 2010 1:50 pm
Hi, I know that the subject in heading is quite old but would anyone out there know whether the rear WP shock of a ktm640 lc4 is interchangable with the one for a 2002 Baghira Black Panther.
kurtc875
Postby kman.45 » Wed Oct 20, 2010 7:42 pm
I know the forks are 300EXC vintage from late 90s early 2000s (at least that's the way Parts Unlimited has it..), so maybe a 640 shock from around that time frame might also work. sorry don't know for sure.
2003 Baghira 660 SM/E
2008 Ducati Multistrada 1100S
kman.45
Users browsing this forum: No registered users and 146 guests
